Aller au contenu principal
Alienware M17-R1 CPU Cooler Replacement
Ce dont vous avez besoin
  1. Alienware M17-R1 CPU Cooler Replacement, Battery: étape 1, image 1 de 1
    • Push the slider until the battery is released from its socket.
  2. Alienware M17-R1 CPU Cooler Replacement: étape 2, image 1 de 1
    • Lift the battery using your fingers.
    • It may be necessary to use a plastic opening tool.
  3. Alienware M17-R1 CPU Cooler Replacement, CPU Cooler: étape 3, image 1 de 1
    • First begin by placing the laptop on a hard flat surface.
    • Remove the nine 3 mm screws that secure the back panel using a Phillips #1 screwdriver.
  4. Alienware M17-R1 CPU Cooler Replacement: étape 4, image 1 de 1
    • Once the cover has been removed, locate the CPU Cooler to begin the replacement.
  5. Alienware M17-R1 CPU Cooler Replacement: étape 5, image 1 de 1
    • Remove the six 7 mm screws using a Phillips #1 and then use the pry tool to unplug the fan before removing the CPU Cooler.
    • Screws 1 through 4 are integrated into the cooler and will come all the way out.
  6. Alienware M17-R1 CPU Cooler Replacement: étape 6, image 1 de 1
    • Once all screws have been removed and the cooler has been unplugged, gently lift the cooler out of its compartment to install the new cooling fan.
LXA054
Membre depuis le 10/09/18
337 Réputation
3 tutoriels rédigés
Équipe
Sam Houston State, Team S15-G2, Blackburne Fall 2018 Membre de l'équipe Sam Houston State, Team S15-G2, Blackburne Fall 2018
SHSU-BLACKBURNE-F18S15G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 12
Total : 729
