Aller au contenu principal
Alienware M17-R1 RAM Replacement
Ce dont vous avez besoin
  1. Alienware M17-R1 RAM Replacement, Battery: étape 1, image 1 de 1
    • Push the slider until the battery is released from its socket.
  2. Alienware M17-R1 RAM Replacement: étape 2, image 1 de 1
    • Lift the battery using your fingers.
    • It may be necessary to use a plastic opening tool.
  3. Alienware M17-R1 RAM Replacement, RAM: étape 3, image 1 de 1
    • Place laptop down on a hard flat surface to begin the disassembly.
  4. Alienware M17-R1 RAM Replacement: étape 4, image 1 de 2 Alienware M17-R1 RAM Replacement: étape 4, image 2 de 2
    • Remove the nine 3 mm screws that secure the cover using a Phillips #1 screwdriver.
  5. Alienware M17-R1 RAM Replacement: étape 5, image 1 de 1
    • Once the cover is removed, locate the RAM compartment to begin the replacement.
  6. Alienware M17-R1 RAM Replacement: étape 6, image 1 de 2 Alienware M17-R1 RAM Replacement: étape 6, image 2 de 2
    • After locating the RAM, gently pull the two metal clips outward and lift the RAM card out of its socket.
    • The card will pop up once it has been released and can be removed.
  7. Alienware M17-R1 RAM Replacement: étape 7, image 1 de 1
    • To insert the new RAM, place it on top of the socket and carefully apply downward pressure until it snaps into place.
LXA054
Membre depuis le 10/09/18
337 Réputation
3 tutoriels rédigés
Équipe
Sam Houston State, Team S15-G2, Blackburne Fall 2018 Membre de l'équipe Sam Houston State, Team S15-G2, Blackburne Fall 2018
SHSU-BLACKBURNE-F18S15G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 11
Total : 647
