Aller au contenu principal
Alienware M17x Hard Drive Replacement
Ce dont vous avez besoin
  1. Alienware M17x Hard Drive Replacement, Battery: étape 1, image 1 de 2 Alienware M17x Hard Drive Replacement, Battery: étape 1, image 2 de 2
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Alienware M17x Hard Drive Replacement: étape 2, image 1 de 1
    • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
    • Slide cover forward then carefully lift up.
  3. Alienware M17x Hard Drive Replacement: étape 3, image 1 de 1
    • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
  4. Alienware M17x Hard Drive Replacement: étape 4, image 1 de 2 Alienware M17x Hard Drive Replacement: étape 4, image 2 de 2
    • Carefully use the Plastic Opening Tool to unplug the battery.
    • Lift the battery up and out to remove.
  5. Alienware M17x Hard Drive Replacement, Hard Drive: étape 5, image 1 de 1
    • With the laptop flipped over, cover removed, and battery removed; continue by locating your hard drive(s).
  6. Alienware M17x Hard Drive Replacement: étape 6, image 1 de 3 Alienware M17x Hard Drive Replacement: étape 6, image 2 de 3 Alienware M17x Hard Drive Replacement: étape 6, image 3 de 3
    • Remove the eight 3.5 mm Phillips #0 screws.
    • Remove the hard drive(s), using the Plastic Opening Tool by lifting on the edges and pulling the hard drive up and out.
Mosier Locke
Membre depuis le 09/27/18
729 Réputation
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 12
Total : 2,342
