Aller au contenu principal
Alienware M17x Motherboard Replacement
Ce dont vous avez besoin
  1. Alienware M17x Motherboard Replacement, Battery: étape 1, image 1 de 2 Alienware M17x Motherboard Replacement, Battery: étape 1, image 2 de 2
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Alienware M17x Motherboard Replacement: étape 2, image 1 de 1
    • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
    • Slide cover forward then carefully lift up.
  3. Alienware M17x Motherboard Replacement: étape 3, image 1 de 1
    • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
  4. Alienware M17x Motherboard Replacement: étape 4, image 1 de 2 Alienware M17x Motherboard Replacement: étape 4, image 2 de 2
    • Carefully use the Plastic Opening Tool to unplug the battery.
    • Lift the battery up and out to remove.
  5. Alienware M17x Motherboard Replacement, Motherboard: étape 5, image 1 de 1
    • Remove the following screws using a Phillips #0 screwdriver to free the motherboard from the rest of the internal components.
    • A Magnetic Project Mat is recommended to keep track of screws and removed parts.
    • Twelve 5.5 mm Phillips #0 main frame screws.
    • Six 3.5 mm Phillips #0 fan screws.
    • Four 3.5 mm Phillips #0 internal compartment screws.
    • Eight 3.5 mm Phillips #0 Hard Drive screws.
    • Four 3.5 mm Phillips #0 CD Drive screws.
    • After removing the screws NOT marked in red, each corresponding component can be removed, but it is not recommended for this guide.
  6. Alienware M17x Motherboard Replacement: étape 6, image 1 de 3 Alienware M17x Motherboard Replacement: étape 6, image 2 de 3 Alienware M17x Motherboard Replacement: étape 6, image 3 de 3
    • Flip the laptop over so that the Alienware logo is facing the ceiling and open the lid exposing the screen and keyboard.
    • Use a plastic opening tool to pry the keyboard from the base of the computer.
  7. Alienware M17x Motherboard Replacement: étape 7, image 1 de 1
    • Remove five 3.5 mm Phillips #0 screws from the motherboard.
    • Unplug the consumer IR cables on the consumer IR board using a plastic opening tool.
    • Lift the motherboard at an angle and remove it from the computer base.
Mosier Locke
Membre depuis le 09/27/18
729 Réputation
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 18
Total : 1,770
