Aller au contenu principal
Alienware M17x P01E Center Control Cover Replacement
Ce dont vous avez besoin
  1. Alienware M17x P01E Center Control Cover Replacement, Battery: étape 1, image 1 de 1
    • Please power off the computer and deplete the battery before attempting the following step.
  2. Alienware M17x P01E Center Control Cover Replacement: étape 2, image 1 de 2 Alienware M17x P01E Center Control Cover Replacement: étape 2, image 2 de 2
    • Press down on the battery latch and slide it to the left.
    • Lift the battery out once it pops out.
  3. Alienware M17x P01E Center Control Cover Replacement, Compartment Door: étape 3, image 1 de 1
    • Loosen the two silver Phillips #1 screws.
    • The screws are held to the compartment door by a washer and cannot be removed.
  4. Alienware M17x P01E Center Control Cover Replacement: étape 4, image 1 de 2 Alienware M17x P01E Center Control Cover Replacement: étape 4, image 2 de 2
    • Use your hand to gently lift and remove the compartment door.
  5. Alienware M17x P01E Center Control Cover Replacement, Center Control Cover: étape 5, image 1 de 3 Alienware M17x P01E Center Control Cover Replacement, Center Control Cover: étape 5, image 2 de 3 Alienware M17x P01E Center Control Cover Replacement, Center Control Cover: étape 5, image 3 de 3
    • Remove the two 2mm Phillips #0 screws from the recesses on the left and right side of the processor fan.
  6. Alienware M17x P01E Center Control Cover Replacement: étape 6, image 1 de 2 Alienware M17x P01E Center Control Cover Replacement: étape 6, image 2 de 2
    • Turn the laptop top side up and fully open the display.
    • The center control panel is between the display and the keyboard. Fully opening the display ensures that there is enough room to pry and lift the center control panel.
    • Pry the center control panel up from its left and right edges with the Spudger.
    • The center control panel may require a decent amount of force to pry free. Do not immediately lift the panel from the laptop once it has been pried free. A cable is connected from the laptop to the center control panel.
  7. Alienware M17x P01E Center Control Cover Replacement: étape 7, image 1 de 2 Alienware M17x P01E Center Control Cover Replacement: étape 7, image 2 de 2
    • Lift the center control panel from the laptop.
    • Tilt the center control panel away from the display carefully.
    • Lift the latch open to remove the cable connecting from the laptop to the center control panel.
Grant Dolmat
Membre depuis le 09/17/18
328 Réputation
2 tutoriels rédigés
Équipe
CSU Fullerton, Team S2-G2, Bruce Fall 2018 Membre de l'équipe CSU Fullerton, Team S2-G2, Bruce Fall 2018
CSUF-BRUCE-F18S2G2
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 7
Total : 424
