Introduction
Is your device heating up unexpectedly or making loud noises? Consider using this guide to replace the fan of your device.
Pièces
Aucune pièce nécessaire.
  1. Please power off the computer and deplete the battery before attempting the following step.
    • Please power off the computer and deplete the battery before attempting the following step.
  2. Press down on the battery latch and slide it to the left. Lift the battery out once it pops out.
    • Press down on the battery latch and slide it to the left.
    • Lift the battery out once it pops out.
  3. %Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  4. Loosen the two silver Phillips #1 screws.
    • Loosen the two silver Phillips #1 screws.
    • The screws are held to the compartment door by a washer and cannot be removed.
  5. Use your hand to gently lift and remove the compartment door. Use your hand to gently lift and remove the compartment door.
    • Use your hand to gently lift and remove the compartment door.
  6. Loosen the three black Phillips #1 screws. The screws are held to the fan by a washer and cannot be removed. The screws are held to the fan by a washer and cannot be removed.
    • Loosen the three black Phillips #1 screws.
    • The screws are held to the fan by a washer and cannot be removed.
  7. Use your hand to gently lift the fan from the laptop. Careful not to pull too hard on CPU fan cable.
    • Use your hand to gently lift the fan from the laptop.
    • Careful not to pull too hard on CPU fan cable.
Kevin Palacios
Membre depuis le 17/09/2018
169 Réputation
2 tutoriels rédigés
Équipe
CSU Fullerton, Team S2-G2, Bruce Fall 2018 Membre de l'équipe CSU Fullerton, Team S2-G2, Bruce Fall 2018
CSUF-BRUCE-F18S2G2
4 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 73
