Aller au contenu principal
Alienware M17x P01E RAM Replacement
Ce dont vous avez besoin
  1. Alienware M17x P01E RAM Replacement, Battery: étape 1, image 1 de 1
    • Please power off the computer and deplete the battery before attempting the following step.
  2. Alienware M17x P01E RAM Replacement: étape 2, image 1 de 2 Alienware M17x P01E RAM Replacement: étape 2, image 2 de 2
    • Press down on the battery latch and slide it to the left.
    • Lift the battery out once it pops out.
  3. Alienware M17x P01E RAM Replacement, Compartment Door: étape 3, image 1 de 1
    • Loosen the two silver Phillips #1 screws.
    • The screws are held to the compartment door by a washer and cannot be removed.
  4. Alienware M17x P01E RAM Replacement: étape 4, image 1 de 2 Alienware M17x P01E RAM Replacement: étape 4, image 2 de 2
    • Use your hand to gently lift and remove the compartment door.
  5. Alienware M17x P01E RAM Replacement, RAM: étape 5, image 1 de 2 Alienware M17x P01E RAM Replacement, RAM: étape 5, image 2 de 2
    • Remove the Phillips #1 screw holding the plate.
    • Use your hand to remove the plate.
    • The screw is held to the plate by a washer and cannot be removed.
  6. Alienware M17x P01E RAM Replacement: étape 6, image 1 de 2 Alienware M17x P01E RAM Replacement: étape 6, image 2 de 2
    • Pull the clips to the side away from each other. The RAM will pop up.
    • Lift forward and gently loosen to pull out of socket.
  7. Alienware M17x P01E RAM Replacement: étape 7, image 1 de 1
    • For the second RAM card use the opening tool to gently lift the RAM card forward.
2 autres ont terminé cette réparation.
Jose
Membre depuis le 09/19/18
324 Réputation
3 tutoriels rédigés
Équipe
CSU Fullerton, Team S2-G2, Bruce Fall 2018 Membre de l'équipe CSU Fullerton, Team S2-G2, Bruce Fall 2018
CSUF-BRUCE-F18S2G2
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 9
Total : 695
