Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
If your RAM can't keep up with the demands of today's mundane and daily tasks, use this guide to remove and replace your RAM cards.
Pièces
Aucune pièce spécifiée.
  1. Turn off your laptop before starting. Flip the laptop over so the model stickers face the ceiling.
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
    • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
    • Slide cover forward then carefully lift up.
  3. Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
    • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
  4. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  5. Carefully use the Plastic Opening Tool to unplug the battery. Lift the battery up and out to remove.
    • Carefully use the Plastic Opening Tool to unplug the battery.
    • Lift the battery up and out to remove.
  6. With the laptop flipped over, cover removed, and battery removed; continue by locating your RAM cards. With the laptop flipped over, cover removed, and battery removed; continue by locating your RAM cards.
    • With the laptop flipped over, cover removed, and battery removed; continue by locating your RAM cards.
  7. Remove the top RAM card by pressing the tabs to the sides using the Plastic Opening Tool. Once the top card has popped up, carefully remove it by holding the sides and sliding it out.
    • Remove the top RAM card by pressing the tabs to the sides using the Plastic Opening Tool.
    • Once the top card has popped up, carefully remove it by holding the sides and sliding it out.
  8. Remove the bottom RAM card in a similar manner.
    • Remove the bottom RAM card in a similar manner.
Mosier Locke
Membre depuis le 27/09/2018
654 Réputation
5 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 7
Total : 170
