Aller au contenu principal
Alienware P18G M14X R1 Battery Replacement
Ce dont vous avez besoin
  1. Alienware P18G M14X R1 Battery Replacement, Back Cover: étape 1, image 1 de 1
    • Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
    • The screws will not be able to be removed from the back cover. They can only be loosened or tightened.
  2. Alienware P18G M14X R1 Battery Replacement: étape 2, image 1 de 1
    • Slide back cover forward using your thumbs.
  3. Alienware P18G M14X R1 Battery Replacement: étape 3, image 1 de 1
    • Lift up the cover and set aside exposing the internals of the computer.
  4. Alienware P18G M14X R1 Battery Replacement, Battery: étape 4, image 1 de 1
    • Make sure the laptop is turned off before starting.
    • Using PH1 screwdriver loosen the two screws on the right of the battery.
    • The screws will not be able to be removed from the battery. They can only be loosened or tightened.
  5. Alienware P18G M14X R1 Battery Replacement: étape 5, image 1 de 2 Alienware P18G M14X R1 Battery Replacement: étape 5, image 2 de 2
    • Pull battery up using the tab provided.
  6. Alienware P18G M14X R1 Battery Replacement: étape 6, image 1 de 1
    • Disconnect the clip connecting the battery to the computer.
    • Set battery aside.
2 autres ont terminé cette réparation.
Andonaq Grozdani
Membre depuis le 03/01/18
892 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G2, Simcock Spring 2018 Membre de l'équipe UMass Dartmouth, Team S2-G2, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 30
Total : 1,976
