Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Alienware X51 R2/R3 CPU Replacement
Ce dont vous avez besoin
  1. Alienware X51 R2/R3 CPU Replacement, CPU (Processor): étape 1, image 1 de 1
    • The first step is to unscrew this screw. After that you want to slide the case cover off of the computer.
    Demander à FixBot
  2. Alienware X51 R2/R3 CPU Replacement: étape 2, image 1 de 1
    • After the Case is open, you want to disconnect the cable to the LED's on the system case.
    Demander à FixBot
  3. Alienware X51 R2/R3 CPU Replacement: étape 3, image 1 de 1
    • You will need to unscrew two screws from the fan cover. The screws are located in the red markers. Then you will gently lift the cover out of the case.
    • Afterwards, you will need to unplug the fan from the motherboard at the blue marker.
    Demander à FixBot
  4. Alienware X51 R2/R3 CPU Replacement: étape 4, image 1 de 1
    • Using the screwdriver, unscrew the 4 screws securing the heat sink and fan to the motherboard. THE SCREWS DO NOT COME OUT ALL THE WAY.
    • Afterward, lift the heat sink out of the case to reveal the processor.
    Demander à FixBot
  5. Alienware X51 R2/R3 CPU Replacement: étape 5, image 1 de 1
    • If there is already thermal paste on the heat sink and/or processor, clean it off using the ArctiClean.
    • Carefully move the lever to release the processor bracket. Then, flip the bracket over, and CAREFULLY remove the processor BY THE EDGES.
    Demander à FixBot
To reassemble your device, follow these instructions in reverse order with the new processor installed. Don't forget to apply thermal grease to the new CPU.
2 autres ont terminé cette réparation.
rcschwartz709
Membre depuis le 07/02/16
220 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 12
30 derniers jours : 67
Total : 3,181
