Introduction
The Alienware X51 R1, R2, and R3 shut down randomly when a computer's RAM starts to fail. This can be problematic with wear but is easy to fix with basic tooling. Before beginning the repair, a user must have a Phillips-head screwdriver and two eight-gigabyte RAM memory cards for a total of sixteen gigabytes.
NOTE: use an anti-static wrist strap when working to prevent circuitry damage.
Ce dont vous avez besoin
Place the PC so the name "Alienware" is on top and facing you.
Slide the front panel towards you and lift up.
Remove the two 2.0 mm screws holding the fan protector in place using a Phillips #1 screwdriver.
Remove the protector holding the fan in.
