Aller au contenu principal
Alienware m15 R6 Speakers Replacement
Ce dont vous avez besoin
  1. Alienware m15 R6 Speakers Replacement, Base Cover: étape 1, image 1 de 1
    • Remove the two screws (M2.5x5) that secure the base cover to the palm-rest and keyboard assembly.
    • New line. Loosen the two captive screws (M2.5x8.5+3.5) that secure the base cover to the palm-rest and keyboard assembly
    • Loosen the four captive screws (M2.5x1.7+3.3) that secure the base cover to the palm-rest and keyboard assembly.
  2. Alienware m15 R6 Speakers Replacement: étape 2, image 1 de 1
    • Using your fingertips, pry open the base cover from the middle of the front edge of base cover, and then pry the left and right sides of the base cover.
    • Lift the base cover off the palm-rest and keyboard assembly.
  3. Alienware m15 R6 Speakers Replacement: étape 3, image 1 de 1
    • Disconnect the battery cable from the system board.
    • Turn your computer over and press the power button for 20 seconds to drain the flea power
  4. Alienware m15 R6 Speakers Replacement, Battery: étape 4, image 1 de 1
    • Disconnect the battery cable from the system board (applicable only if not disconnected earlier).
    • NOTE: After removing the battery, store the battery cable safely. The replacement battery will not be shipped with thebattery cable. If you want to replace the battery cable, it has to be purchased separately.
    • Remove the four screws (M2x4) that secure the battery to the palm-rest and keyboard assembly.
    • Remove the four screws (M2x3) that secure the battery to the palm-rest and keyboard assembly.
    • Lift the battery off the palm-rest and keyboard assembly.
  5. Alienware m15 R6 Speakers Replacement, Removing the solid-state drive in SSD slot two: étape 5, image 1 de 2 Alienware m15 R6 Speakers Replacement, Removing the solid-state drive in SSD slot two: étape 5, image 2 de 2
    • Remove the two screws (M2x4) that secure the thermal shield to the solid-state drive and system board.
    • Lift the thermal shield off the solid-state drive.
    • Slide and lift the solid-state drive off the solid-state drive slot on the system board.
  6. Alienware m15 R6 Speakers Replacement, Procedure to move the screw mount in SSD slot two: étape 6, image 1 de 1
    • Slide to remove the screw mount from the palm-rest and keyboard assembly.
    • Slide the screw mount into the other screw mount slot on the palm-rest and keyboard assembly.
  7. Alienware m15 R6 Speakers Replacement, Speakers: étape 7, image 1 de 1
    • Disconnect the speaker cable from the system board.
    • Peel the tape that secures the speaker cable to the palm-rest and keyboard assembly.
    • Peel the tape that secures the speaker cable to the touchpad bracket.
    • Note the speaker cable routing, and remove the speaker cable from the routing guides on the palm-rest and keyboard assembly.
    • Lift the speakers, along with the cables, off the palm-rest and keyboard assembly.
Andrzej
Membre depuis le 02/17/23
1 672 Réputation
18 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 19
Total : 147
