Introduction
Prerequisites
- Follow the procedure in Before working inside your computer.
Ce dont vous avez besoin
Remove the two screws (M2.5x5) that secure the base cover to the palm-rest and keyboard assembly.
New line. Loosen the two captive screws (M2.5x8.5+3.5) that secure the base cover to the palm-rest and keyboard assembly
Loosen the four captive screws (M2.5x1.7+3.3) that secure the base cover to the palm-rest and keyboard assembly.
Disconnect the battery cable from the system board (applicable only if not disconnected earlier).
Remove the four screws (M2x4) that secure the battery to the palm-rest and keyboard assembly.
Remove the four screws (M2x3) that secure the battery to the palm-rest and keyboard assembly.
Lift the battery off the palm-rest and keyboard assembly.
Remove the speaker cable from the routing guides on the palm-rest and keyboard assembly.
Open the latch and disconnect the touchpad cable from the system board.
Open the latch and disconnect the touchpad cable from the touchpad.
Remove the two (M2.5x2.5) screws that secure the touchpad bracket to the palm-rest and keyboard assembly.
Lift the touchpad bracket off the palm-rest and keyboard assembly.
Remove the two (M2x2) screws that secure the touchpad to the palm-rest and keyboard assembly.
Lift the touchpad off the palm-rest and keyboard assembly.
