Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
Fuses are a common component in many electronic devices. They limit the current flowing to the device. If too much current is passed through them, they can become damaged or blown. To replace a fuse in the Alpine MRV-M500 you will need a pair of needle-nosed pliers and new 30A fuses.
Pièces
  1. Fuses are on the front panel. Use needle nosed pliers to remove fuse. To install the new fuse, simply insert it in the same orientation as the original.
    • Fuses are on the front panel.
    • Use needle nosed pliers to remove fuse.
    • To install the new fuse, simply insert it in the same orientation as the original.
    • This may require some force.
  2. Manta Precision Bit Set
    112 embouts pour toute réparation.
    Upgrade Your Toolbox
Ligne d'arrivée
2 autre(s) ont terminé cette réparation.
Eric Gaulke
Membre depuis le 17/09/2018
527 Réputation
3 tutoriels rédigés
Équipe
Washington State, Team S2-G6, Hope Fall 2018 Membre de l'équipe Washington State, Team S2-G6, Hope Fall 2018
WSU-HOPE-F18S2G6
4 membres
3 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 25
Total : 349
