Aller au contenu principal
Altec Lansing BoomJacket 2 Speaker Replacement
Ce dont vous avez besoin
  1. Altec Lansing BoomJacket 2 Speaker Replacement, Altec Lansing BoomJacket 2 Disassembly: étape 1, image 1 de 2 Altec Lansing BoomJacket 2 Speaker Replacement, Altec Lansing BoomJacket 2 Disassembly: étape 1, image 2 de 2
    • Starting from any side, use your fingers to grab the black rubber sleeve and gently pull away from the speaker on both sides.
  2. Altec Lansing BoomJacket 2 Speaker Replacement: étape 2, image 1 de 2 Altec Lansing BoomJacket 2 Speaker Replacement: étape 2, image 2 de 2
    • Using your fingers, grab the blue sleeve from one side and pull away from the unit.
  3. Altec Lansing BoomJacket 2 Speaker Replacement: étape 3, image 1 de 1
    • At each of the marked pry spots, use the metal spudger to lift the speaker grill away from the case.
    • Avoid using excessive force to prevent bending the grill.
  4. Altec Lansing BoomJacket 2 Speaker Replacement: étape 4, image 1 de 2 Altec Lansing BoomJacket 2 Speaker Replacement: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use the tweezers to remove the six rubber stoppers. There are four in the middle and two on the sides.
  5. Altec Lansing BoomJacket 2 Speaker Replacement: étape 5, image 1 de 1
    • Use the PH1 Phillips screwdriver to remove the six 12mm screws that lie underneath each rubber stopper.
  6. Altec Lansing BoomJacket 2 Speaker Replacement: étape 6, image 1 de 1
    • Gently pull apart the front panel from the base of the speaker.
  7. Altec Lansing BoomJacket 2 Speaker Replacement, Speaker: étape 7, image 1 de 2 Altec Lansing BoomJacket 2 Speaker Replacement, Speaker: étape 7, image 2 de 2
    • Unscrew the four screws holding the speaker in place.
  8. Altec Lansing BoomJacket 2 Speaker Replacement: étape 8, image 1 de 2 Altec Lansing BoomJacket 2 Speaker Replacement: étape 8, image 2 de 2
    • Unscrew the two screws on the smaller speaker.
    • Pull the small speaker through the larger speaker hole.
Zach Braaten
Membre depuis le 07/12/18
537 Réputation
4 tutoriels rédigés
Équipe
UW Tacoma, Team S1-G4, Cardinal Summer 2018 Membre de l'équipe UW Tacoma, Team S1-G4, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G4
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 13
Total : 483
