Aller au contenu principal
Altec Lansing BoomJacket Speaker Replacement
Ce dont vous avez besoin
  1. Altec Lansing BoomJacket Speaker Replacement, Speaker: étape 1, image 1 de 1
    • Using your hands, remove the pegs (4+4) from the front and back of the speaker.
  2. Altec Lansing BoomJacket Speaker Replacement: étape 2, image 1 de 1
    • Remove the outer black rubber housing of the speaker.
  3. Altec Lansing BoomJacket Speaker Replacement: étape 3, image 1 de 1
    • Remove the inner blue rubber housing from the speaker.
  4. Altec Lansing BoomJacket Speaker Replacement: étape 4, image 1 de 1
    • Pull out the two black wire meshes using a metal spudger.
    • Be careful not to damage the metal casing.
  5. Altec Lansing BoomJacket Speaker Replacement: étape 5, image 1 de 2 Altec Lansing BoomJacket Speaker Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Using tweezers remove the rubber stoppers (4 at the back + 2 at the front).
  6. Altec Lansing BoomJacket Speaker Replacement: étape 6, image 1 de 1
    • Using the size PH1 screwdriver remove the screws (4 around each speaker).
  7. Altec Lansing BoomJacket Speaker Replacement: étape 7, image 1 de 1
    • Pull the case apart and you will be able to see all the components inside the speaker.
  8. Altec Lansing BoomJacket Speaker Replacement: étape 8, image 1 de 1
    • Remove the speakers (not entirely because of the wiring) by gently pulling each speaker up.
Ryan Byrnes
Membre depuis le 04/12/17
872 Réputation
5 tutoriels rédigés
2 commentaires
Where do I find the correct part to replace the charging port on my boom jacket?
Rockstar - Réponse
1.1" External Magnetic Type Round Slim Plastic Shell Speaker 8 Ohm 0.25W 2 Pcs
Eeshton -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 6
Total : 765
