Aller au contenu principal
Altec Lansing Mini Lifejacket 2 Battery Replacement
Ce dont vous avez besoin
  1. Altec Lansing Mini Lifejacket 2 Battery Replacement, Back Panel: étape 1, image 1 de 3 Altec Lansing Mini Lifejacket 2 Battery Replacement, Back Panel: étape 1, image 2 de 3 Altec Lansing Mini Lifejacket 2 Battery Replacement, Back Panel: étape 1, image 3 de 3
    • Use the spudger to remove the eight black pins from the front and back of the wire screens.
  2. Altec Lansing Mini Lifejacket 2 Battery Replacement: étape 2, image 1 de 3 Altec Lansing Mini Lifejacket 2 Battery Replacement: étape 2, image 2 de 3 Altec Lansing Mini Lifejacket 2 Battery Replacement: étape 2, image 3 de 3
    • Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
    • Removing the secondary pins from the rubber casing is optional.
  3. Altec Lansing Mini Lifejacket 2 Battery Replacement: étape 3, image 1 de 2 Altec Lansing Mini Lifejacket 2 Battery Replacement: étape 3, image 2 de 2
    • Remove both black and orange layers from the speaker body.
  4. Altec Lansing Mini Lifejacket 2 Battery Replacement: étape 4, image 1 de 3 Altec Lansing Mini Lifejacket 2 Battery Replacement: étape 4, image 2 de 3 Altec Lansing Mini Lifejacket 2 Battery Replacement: étape 4, image 3 de 3
    • Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
    • Slide the mounting plate out to remove it.
  5. Altec Lansing Mini Lifejacket 2 Battery Replacement: étape 5, image 1 de 2 Altec Lansing Mini Lifejacket 2 Battery Replacement: étape 5, image 2 de 2
    • Pry off the wire mesh on both sides using a metal spudger.
    • Be gentle to avoid bending the mesh.
  6. Altec Lansing Mini Lifejacket 2 Battery Replacement: étape 6, image 1 de 2 Altec Lansing Mini Lifejacket 2 Battery Replacement: étape 6, image 2 de 2
    Outil utilisé dans cette étape :
    • Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
  7. Altec Lansing Mini Lifejacket 2 Battery Replacement: étape 7, image 1 de 1
    • Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
  8. Altec Lansing Mini Lifejacket 2 Battery Replacement: étape 8, image 1 de 1
    • Pull the case apart to access the interior components.
  9. Altec Lansing Mini Lifejacket 2 Battery Replacement: étape 9, image 1 de 3 Altec Lansing Mini Lifejacket 2 Battery Replacement: étape 9, image 2 de 3 Altec Lansing Mini Lifejacket 2 Battery Replacement: étape 9, image 3 de 3
    • To remove the back panel, gently pull out its wire harness.
  10. Altec Lansing Mini Lifejacket 2 Battery Replacement, Battery: étape 10, image 1 de 3 Altec Lansing Mini Lifejacket 2 Battery Replacement, Battery: étape 10, image 2 de 3 Altec Lansing Mini Lifejacket 2 Battery Replacement, Battery: étape 10, image 3 de 3
    • Disconnect the battery from the motherboard.
    • The battery is not secured within the case and can be removed after detaching its wiring from the circuit board.
8 autres ont terminé cette réparation.
Stephen Albrecht
Membre depuis le 02/14/18
1 053 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S3-G2, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S3-G2, Nance Spring 2018
USFT-NANCE-S18S3G2
4 membres
4 tutoriels rédigés
11 commentaires
Where can you get the batteries? Altec Lansing doesn’t carry them.
alanp5 - Réponse
Search for MCR18650 battery. They are available.
F Hickisch - Réponse
Hickisch, I appreciate your guide on replacing this battery, but I beg to differ that replacement batteries are “available.” I keep getting sent batteries with 3-wire connectors instead of 2-wire. Plz send me a link, plz. Gracias.
rudy.ch.garcia - Réponse
Sounds like you need to find another source instead of aliexpress or ebay. Digikey has them with the correct 2 wire connection. It's just a standard 18650 battery with the wires spot welded to the positive and negative terminals. Anything with a 3rd wire is likely meant as a charge sensing wire for a batter that has on board circuitry.
rchuncleskeleton -
for the mini life jacket 3, the motherboard is upside down so you need to remove it to unplug the battery.
Edgar Corral (Tramarius) - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 18
30 derniers jours : 60
Total : 22,759
