Introduction
Use this guide to replace the motherboard in your Altec Lansing Mini Lifejacket 2 if the bluetooth chip, microphone, or another electronic component has failed.
Disconnect the battery from the motherboard.
  • Disconnect the battery from the motherboard.
  • The battery is not secured within the case and can be removed after detaching its wiring from the circuit board.
Ajouter un commentaire
Unplug the remaining four wire harnesses attached to the circuit board
  • Unplug the remaining four wire harnesses attached to the circuit board
  • Remove the three 9.1mm Phillips #1 screws located on the circuit board.
  • Remove the motherboard.
Stephen Albrecht
Membre depuis le 14/02/2018
675 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S3-G2, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S3-G2, Nance Spring 2018
USFT-NANCE-S18S3G2
4 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 15
30 derniers jours : 77
Total : 294
