Aller au contenu principal
Altec Lansing Mini Lifejacket 2 Motherboard Replacement
Ce dont vous avez besoin
  1. Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Back Panel: étape 1, image 1 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Back Panel: étape 1, image 2 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Back Panel: étape 1, image 3 de 3
    • Use the spudger to remove the eight black pins from the front and back of the wire screens.
  2. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: étape 2, image 1 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: étape 2, image 2 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: étape 2, image 3 de 3
    • Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
    • Removing the secondary pins from the rubber casing is optional.
  3. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: étape 3, image 1 de 2 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: étape 3, image 2 de 2
    • Remove both black and orange layers from the speaker body.
  4. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: étape 4, image 1 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: étape 4, image 2 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: étape 4, image 3 de 3
    • Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
    • Slide the mounting plate out to remove it.
  5. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: étape 5, image 1 de 2 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: étape 5, image 2 de 2
    • Pry off the wire mesh on both sides using a metal spudger.
    • Be gentle to avoid bending the mesh.
  6. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: étape 6, image 1 de 2 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: étape 6, image 2 de 2
    Outil utilisé dans cette étape :
    • Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
  7. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: étape 7, image 1 de 1
    • Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
  8. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: étape 8, image 1 de 1
    • Pull the case apart to access the interior components.
  9. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: étape 9, image 1 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: étape 9, image 2 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: étape 9, image 3 de 3
    • To remove the back panel, gently pull out its wire harness.
  10. Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Battery: étape 10, image 1 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Battery: étape 10, image 2 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Battery: étape 10, image 3 de 3
    • Disconnect the battery from the motherboard.
    • The battery is not secured within the case and can be removed after detaching its wiring from the circuit board.
  11. Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Motherboard: étape 11, image 1 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Motherboard: étape 11, image 2 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Motherboard: étape 11, image 3 de 3
    • Unplug the remaining four wire harnesses attached to the circuit board
  12. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: étape 12, image 1 de 2 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: étape 12, image 2 de 2
    • Remove the three 9.1mm Phillips #1 screws located on the circuit board.
  13. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: étape 13, image 1 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: étape 13, image 2 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: étape 13, image 3 de 3
    • Remove the motherboard.
2 autres ont terminé cette réparation.
Stephen Albrecht
Membre depuis le 02/14/18
1 053 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S3-G2, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S3-G2, Nance Spring 2018
USFT-NANCE-S18S3G2
4 membres
4 tutoriels rédigés
6 commentaires
I own the IMW778-BLU-TA model. Where can I find a replacement motherboard for it??
Nick Cote - Réponse
same for me, anyone knows where can I find a replacement of the motherboard? thx
Travis - Réponse
need back panel replacement
rahul pande - Réponse
Same here! Loved the product. Can not afford to buy something else.
Mr Shopper - Réponse
I need 2 the board for charging,usb,aux cord that plugs into motherboard.
John Proffit - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 14
Total : 5,586
