Aller au contenu principal
Altec Lansing Mini Lifejacket 2 Speaker Replacement
Ce dont vous avez besoin
  1. Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: étape 1, image 1 de 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: étape 1, image 2 de 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: étape 1, image 3 de 3
    • Use the spudger to remove the eight black pins from the front and back of the wire screens.
  2. Altec Lansing Mini Lifejacket 2 Speaker Replacement: étape 2, image 1 de 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: étape 2, image 2 de 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: étape 2, image 3 de 3
    • Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
    • Removing the secondary pins from the rubber casing is optional.
  3. Altec Lansing Mini Lifejacket 2 Speaker Replacement: étape 3, image 1 de 2 Altec Lansing Mini Lifejacket 2 Speaker Replacement: étape 3, image 2 de 2
    • Remove both black and orange layers from the speaker body.
  4. Altec Lansing Mini Lifejacket 2 Speaker Replacement: étape 4, image 1 de 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: étape 4, image 2 de 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: étape 4, image 3 de 3
    • Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
    • Slide the mounting plate out to remove it.
  5. Altec Lansing Mini Lifejacket 2 Speaker Replacement: étape 5, image 1 de 2 Altec Lansing Mini Lifejacket 2 Speaker Replacement: étape 5, image 2 de 2
    • Pry off the wire mesh on both sides using a metal spudger.
    • Be gentle to avoid bending the mesh.
  6. Altec Lansing Mini Lifejacket 2 Speaker Replacement: étape 6, image 1 de 2 Altec Lansing Mini Lifejacket 2 Speaker Replacement: étape 6, image 2 de 2
    Outil utilisé dans cette étape :
    • Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
  7. Altec Lansing Mini Lifejacket 2 Speaker Replacement: étape 7, image 1 de 1
    • Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
  8. Altec Lansing Mini Lifejacket 2 Speaker Replacement: étape 8, image 1 de 1
    • Pull the case apart to access the interior components.
  9. Altec Lansing Mini Lifejacket 2 Speaker Replacement: étape 9, image 1 de 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: étape 9, image 2 de 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: étape 9, image 3 de 3
    • To remove the back panel, gently pull out its wire harness.
  10. Altec Lansing Mini Lifejacket 2 Speaker Replacement, Speaker: étape 10, image 1 de 2 Altec Lansing Mini Lifejacket 2 Speaker Replacement, Speaker: étape 10, image 2 de 2
    • Remove the three 9.3 mm Phillips #1 screws on the speaker cover.
  11. Altec Lansing Mini Lifejacket 2 Speaker Replacement: étape 11, image 1 de 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: étape 11, image 2 de 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: étape 11, image 3 de 3
    • To remove the speaker, gently pull out the its wire harness.
  12. Altec Lansing Mini Lifejacket 2 Speaker Replacement: étape 12, image 1 de 2 Altec Lansing Mini Lifejacket 2 Speaker Replacement: étape 12, image 2 de 2
    • Remove the rubber ring from the rim of the speaker.
    • This ring helps keep water from entering the device. Be careful to position it correctly during reassembly.
Stephen Albrecht
Membre depuis le 02/14/18
1 053 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S3-G2, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S3-G2, Nance Spring 2018
USFT-NANCE-S18S3G2
4 membres
4 tutoriels rédigés
3 commentaires
What speaker should we be getting to replace the faulty speaker, including the wires needed to plug into the slots on the board?
russell rogge - Réponse
Where can I get this speaker parts?
T Rex movies - Réponse
Where can I get a complete power circuit board from for a Imw575 as mine is completely broken thank you
Paul Williams - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 4
30 derniers jours : 11
Total : 4,281
