Aller au contenu principal
Amazon Echo Dot 2nd Generation Ribbon Cable Replacement
Ce dont vous avez besoin
  1. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement, Ribbon Cable: étape 1, image 1 de 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement, Ribbon Cable: étape 1, image 2 de 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement, Ribbon Cable: étape 1, image 3 de 3
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
  2. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: étape 2, image 1 de 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: étape 2, image 2 de 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: étape 2, image 3 de 3
    • Use a T8 screwdriver bit to unscrew the 1.6mm four screws.
    • Remove the black cylindrical base
  3. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: étape 3, image 1 de 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: étape 3, image 2 de 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: étape 3, image 3 de 3
    • Use the metal spudger to lift the ZIF connector
    • Remove the ribbon cable from the slot
  4. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: étape 4, image 1 de 1
    • Remove the motherboard
  5. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: étape 5, image 1 de 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: étape 5, image 2 de 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: étape 5, image 3 de 3
    • Remove the silver divider
    • Remove the black rubber divider
    • Remove the plastic white frame
  6. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: étape 6, image 1 de 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: étape 6, image 2 de 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: étape 6, image 3 de 3
    • Remove the ribbon cable from the slot on the LED/speaker board
4 autres ont terminé cette réparation.
Errica Snelling
Membre depuis le 10/09/17
652 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S1-G3, Leahy Fall 2017 Membre de l'équipe USF Tampa, Team S1-G3, Leahy Fall 2017
USFT-LEAHY-F17S1G3
3 membres
12 tutoriels rédigés
5 commentaires
Where do you get the replacement cable from?
jonathan kabitzke - Réponse
Yes, where can one get replacement ribbon cables?
Armando Morreale - Réponse
Malcolm oakley - Réponse
I need a replacement as well now was using a pointed tweezers when putting it back together and stabbed the cable need to find part and order from the uk
Barrie Gash - Réponse
no cable available, just waiting for donors
Ray Floyd Cabrera - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 29
Total : 2,459
