Aller au contenu principal
Amazon Echo Dot 2nd Generation Speaker Replacement
Ce dont vous avez besoin
  1. Amazon Echo Dot 2nd Generation Speaker Replacement, Speaker: étape 1, image 1 de 3 Amazon Echo Dot 2nd Generation Speaker Replacement, Speaker: étape 1, image 2 de 3 Amazon Echo Dot 2nd Generation Speaker Replacement, Speaker: étape 1, image 3 de 3
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
  2. Amazon Echo Dot 2nd Generation Speaker Replacement: étape 2, image 1 de 3 Amazon Echo Dot 2nd Generation Speaker Replacement: étape 2, image 2 de 3 Amazon Echo Dot 2nd Generation Speaker Replacement: étape 2, image 3 de 3
    • Use the T8 screwdriver bit to unscrew the four 1.6mm torx screws
    • Remove the black, cylindrical base
  3. Amazon Echo Dot 2nd Generation Speaker Replacement: étape 3, image 1 de 1
    • Tap the base against the palm of your hand so that the black speaker component comes out
14 autres ont terminé cette réparation.
Alexis White
Membre depuis le 10/09/17
505 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S1-G3, Leahy Fall 2017 Membre de l'équipe USF Tampa, Team S1-G3, Leahy Fall 2017
USFT-LEAHY-F17S1G3
3 membres
12 tutoriels rédigés
3 commentaires
Where can one purchase the replacement speaker component?
ananomaus - Réponse
Can you inform us were to get replacement speaker please.
John Stead - Réponse
Yeah where can we buy the speaker? This tutorial doesn’t show how to replace it, it shows where to find it
Meghan Craig - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 15
30 derniers jours : 77
Total : 13,176
