Aller au contenu principal
Amazon Echo Dot 3rd Generation Motherboard Replacement
Ce dont vous avez besoin
  1. Amazon Echo Dot 3rd Generation Motherboard Replacement, Casing: étape 1, image 1 de 3 Amazon Echo Dot 3rd Generation Motherboard Replacement, Casing: étape 1, image 2 de 3 Amazon Echo Dot 3rd Generation Motherboard Replacement, Casing: étape 1, image 3 de 3
    • Turn your Echo Dot over so that the barcode is facing upward.
  2. Amazon Echo Dot 3rd Generation Motherboard Replacement: étape 2, image 1 de 2 Amazon Echo Dot 3rd Generation Motherboard Replacement: étape 2, image 2 de 2
    • Use a spudger to lift the adhesive connecting the device and the cover.
  3. Amazon Echo Dot 3rd Generation Motherboard Replacement: étape 3, image 1 de 1
    • Remove the four silver 7.2 mm screws using a T6 Torx screwdriver.
  4. Amazon Echo Dot 3rd Generation Motherboard Replacement: étape 4, image 1 de 2 Amazon Echo Dot 3rd Generation Motherboard Replacement: étape 4, image 2 de 2
    • Lift the casing of the Echo Dot to separate it from the rest of the device.
  5. Amazon Echo Dot 3rd Generation Motherboard Replacement, Motherboard: étape 5, image 1 de 3 Amazon Echo Dot 3rd Generation Motherboard Replacement, Motherboard: étape 5, image 2 de 3 Amazon Echo Dot 3rd Generation Motherboard Replacement, Motherboard: étape 5, image 3 de 3
    • Remove the four 6.2 mm screws from the motherboard using a T6 Torx screwdriver.
    • Remove the three 9.4 mm screws from the motherboard using a T6 Torx screwdriver.
  6. Amazon Echo Dot 3rd Generation Motherboard Replacement: étape 6, image 1 de 3 Amazon Echo Dot 3rd Generation Motherboard Replacement: étape 6, image 2 de 3 Amazon Echo Dot 3rd Generation Motherboard Replacement: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Remove the connecting head linking the motherboard to the device using a pair of tweezers.
    • Remove the old motherboard and replace it with the new one.
Jacquelyn Jones
Membre depuis le 09/15/22
266 Réputation
1 tutoriel rédigé
Équipe
University of Memphis, Team 3-2, Lane Fall 2022 Membre de l'équipe University of Memphis, Team 3-2, Lane Fall 2022
UM-LANE-F22S3G2
4 membres
3 tutoriels rédigés
2 commentaires
Where do we get the parts you bi chh
Fcukermother - Réponse
Amazon does not sell any parts for the Echo devices. Your best and probably only alternative is to buy a used Echo from eBay and use this guide to repair it.
raymondjram -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 82
Total : 1,431
