Aller au contenu principal
Amazon Echo Dot 3rd Generation Speaker Replacement
Ce dont vous avez besoin
  1. Amazon Echo Dot 3rd Generation Speaker Replacement, Casing: étape 1, image 1 de 3 Amazon Echo Dot 3rd Generation Speaker Replacement, Casing: étape 1, image 2 de 3 Amazon Echo Dot 3rd Generation Speaker Replacement, Casing: étape 1, image 3 de 3
    • Turn the Echo Dot over so the barcode is facing up, giving you access to the bottom of the device.
  2. Amazon Echo Dot 3rd Generation Speaker Replacement: étape 2, image 1 de 2 Amazon Echo Dot 3rd Generation Speaker Replacement: étape 2, image 2 de 2
    • Use a spudger to gently lift the adhesive covering between the casing and the device.
  3. Amazon Echo Dot 3rd Generation Speaker Replacement: étape 3, image 1 de 1
    • Use a T6 Torx screwdriver to remove the four 7.2 mm screws located around the corners of the device.
    • Make sure to keep the screws in a safe place for the reassembly process.
  4. Amazon Echo Dot 3rd Generation Speaker Replacement: étape 4, image 1 de 2 Amazon Echo Dot 3rd Generation Speaker Replacement: étape 4, image 2 de 2
    • Gently lift the casing of the device, starting from one side.
    • If the casing is stuck, use the spudger to carefully loosen it along the edges.
    • Be careful not to damage any internal components of the device.
  5. Amazon Echo Dot 3rd Generation Speaker Replacement, Speaker: étape 5, image 1 de 1
    • Remove the four black 8.4 mm screws surrounding the speaker using a JIS #1 screwdriver.
  6. Amazon Echo Dot 3rd Generation Speaker Replacement: étape 6, image 1 de 3 Amazon Echo Dot 3rd Generation Speaker Replacement: étape 6, image 2 de 3 Amazon Echo Dot 3rd Generation Speaker Replacement: étape 6, image 3 de 3
    • Use a spudger to pry the speaker out of the device.
9 autres ont terminé cette réparation.
Elaina Moore
Membre depuis le 09/15/22
178 Réputation
1 tutoriel rédigé
Équipe
University of Memphis, Team 3-2, Lane Fall 2022 Membre de l'équipe University of Memphis, Team 3-2, Lane Fall 2022
UM-LANE-F22S3G2
4 membres
5 tutoriels rédigés
14 commentaires de tutoriel
Now where do I get the new speaker?
Philip Terry - Réponse
Now WHERE do I get the new speaker?
vinodhkumar chejarla - Réponse
WHERE DO WE GET THE REPLACEMENT speaker!?
Jerry Perry - Réponse
I'm not sure if this is gonna work, but I have found a speaker on Amazon which is of the same size, almost the same wattage and same impedance. I'm only not sure about the depth of the speaker.
here is the link: https://amzn.in/d/5CvwhrW
I hope this helped!
Shri Mohan YV -
If you have a new one and the bass is a bit rattly just losten the speaker screws push lightly on the speaker whilst tightening the screws back up. It reduces the pressure and keeps the driver from hitting the case or moving to far out
GrantersG - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 85
30 derniers jours : 388
Total : 8,475
