Introduction
If the speaker of your Amazon Echo Dot 3rd Generation sounds muffled or is distorted in any way, the speaker may need to be replaced. Follow this guide to do so.
The cone shape of your Echo Dot allows your speaker to transmit Alexa's voice in an echo that should ideally carry through the room your device is in.
Check the speaker for other potential causes of sound disruption. Potential causes may include the mesh surrounding your Echo Dot being clouded with debris. Your Echo Dot could also be too close to another device such as a microwave that will cause interference.
Before attempting, make sure the Echo Dot is turned off and unplugged from the external power source.
Ce dont vous avez besoin
Remove the four black 8.4 mm screws surrounding the speaker using a JIS #1 screwdriver.
4 autres ont terminé cette réparation.
9 commentaires
Now where do I get the new speaker?
Now WHERE do I get the new speaker?
WHERE DO WE GET THE REPLACEMENT speaker!?
If you have a new one and the bass is a bit rattly just losten the speaker screws push lightly on the speaker whilst tightening the screws back up. It reduces the pressure and keeps the driver from hitting the case or moving to far out
This is only if the speaker isn’t actually blown.
