Aller au contenu principal
Amazon Echo Power and Speaker Driver Board Replacement
Ce dont vous avez besoin
  1. Amazon Echo Power and Speaker Driver Board Replacement, Power and Speaker Driver Board: étape 1, image 1 de 1
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo Power and Speaker Driver Board Replacement: étape 2, image 1 de 3 Amazon Echo Power and Speaker Driver Board Replacement: étape 2, image 2 de 3 Amazon Echo Power and Speaker Driver Board Replacement: étape 2, image 3 de 3
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo Power and Speaker Driver Board Replacement: étape 3, image 1 de 1
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo Power and Speaker Driver Board Replacement: étape 4, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
  5. Amazon Echo Power and Speaker Driver Board Replacement: étape 5, image 1 de 2 Amazon Echo Power and Speaker Driver Board Replacement: étape 5, image 2 de 2
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
  6. Amazon Echo Power and Speaker Driver Board Replacement: étape 6, image 1 de 3 Amazon Echo Power and Speaker Driver Board Replacement: étape 6, image 2 de 3 Amazon Echo Power and Speaker Driver Board Replacement: étape 6, image 3 de 3
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
10 autres ont terminé cette réparation.
Alexander Albert
Membre depuis le 02/04/16
1 145 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 3-3, Wollert Spring 2016 Membre de l'équipe USF Tampa, Team 3-3, Wollert Spring 2016
USFT-WOLLERT-S16S3G3
4 membres
12 tutoriels rédigés
22 commentaires
It's great that you have provided these instructions. I need to do this with mine. Do you know where I can get a replacement board?
Taylor Wolf - Réponse
Taylor, did you ever find a new board? I need one too.
Mark Hall -
Great instructions BUT ...... THERE IS NO PLACE TO BUY THE BOARD!! (It's proprietary to Amazon) So this instruction is about as useful as jumping out of a plane before asking for a parachute.
blueskymining -
Where do I get a replacement board ?
Sean Burch - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 16
30 derniers jours : 93
Total : 26,814
