Aller au contenu principal
Amazon Echo Show 2nd Gen Sound foam Replacement
Ce dont vous avez besoin
  1. Amazon Echo Show 2nd Gen Sound foam Replacement, Sound foam: étape 1, image 1 de 3 Amazon Echo Show 2nd Gen Sound foam Replacement, Sound foam: étape 1, image 2 de 3 Amazon Echo Show 2nd Gen Sound foam Replacement, Sound foam: étape 1, image 3 de 3
    • Make sure the device is unplugged and powered off.
    • Turn the two screw plugs counterclockwise with a metal spudger until they are 90 degrees from their original position.
    • Pull each of the plugs out.
  2. Amazon Echo Show 2nd Gen Sound foam Replacement: étape 2, image 1 de 3 Amazon Echo Show 2nd Gen Sound foam Replacement: étape 2, image 2 de 3 Amazon Echo Show 2nd Gen Sound foam Replacement: étape 2, image 3 de 3
    • Use the metal spudger to pry and create space between the sound foam and the frame.
    • Once you have sufficiently pried the foam from the frame on each side, detach the sound foam from the frame with your hands.
2 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 16
Total : 1,628
