Aller au contenu principal
Amazon Echo Studio Subwoofer Replacement
Ce dont vous avez besoin
  1. Amazon Echo Studio Subwoofer Replacement, Power Supply Board: étape 1, image 1 de 3 Amazon Echo Studio Subwoofer Replacement, Power Supply Board: étape 1, image 2 de 3 Amazon Echo Studio Subwoofer Replacement, Power Supply Board: étape 1, image 3 de 3
    • Flip the device upside down.
    • Pry up the edge of the rubber base panel with a spudger, then pull the rest of it off by hand.
  2. Amazon Echo Studio Subwoofer Replacement: étape 2, image 1 de 3 Amazon Echo Studio Subwoofer Replacement: étape 2, image 2 de 3 Amazon Echo Studio Subwoofer Replacement: étape 2, image 3 de 3
    • Use a T15 Torx screwdriver to remove the nine 3.2 mm screws.
    • Use a Torx T10 screwdriver to remove the six 2.7 mm screws.
    • After removing the screws, gently lift the base off, with care not to damage any of the connected cables.
  3. Amazon Echo Studio Subwoofer Replacement: étape 3, image 1 de 3 Amazon Echo Studio Subwoofer Replacement: étape 3, image 2 de 3 Amazon Echo Studio Subwoofer Replacement: étape 3, image 3 de 3
    • Before fully removing the base, remove the three attached connectors.
  4. Amazon Echo Studio Subwoofer Replacement: étape 4, image 1 de 2 Amazon Echo Studio Subwoofer Replacement: étape 4, image 2 de 2
    • Now unscrew the the single 10 mm Phillips screw.
    • Remove the power supply board.
  5. Amazon Echo Studio Subwoofer Replacement, Subwoofer: étape 5, image 1 de 1
    • Remove the two screws located across from each other on the outside of the plastic ring shown.
    • Remove the plastic outer ring that hugs the inside of the edges of the device.
    • This may require you to use a soft prying tool to separate it from the outer shell.
  6. Amazon Echo Studio Subwoofer Replacement: étape 6, image 1 de 3 Amazon Echo Studio Subwoofer Replacement: étape 6, image 2 de 3 Amazon Echo Studio Subwoofer Replacement: étape 6, image 3 de 3
    • Remove the two 2.7 mm screws with a T10 Torx screwdriver.
    • Once the screws are removed, take the power supply's baseplate out of the unit.
    • You may need to gently pry the subwoofer's air ports from the round slots In the side of the unit.
  7. Amazon Echo Studio Subwoofer Replacement: étape 7, image 1 de 2 Amazon Echo Studio Subwoofer Replacement: étape 7, image 2 de 2
    • On the silver ring located on the outer edge of the plastic portion of the subwoofer, you will see four 2.7 mm screws. Use a Torx T10 screwdriver to remove them, in order to remove of the subwoofer.
    • Once the four screws have been removed, gently pull the subwoofer out as to not damage the wiring connecting the subwoofer to the main board inside the unit.
    • Follow the wires from the subwoofer to the main board and disconnect the connector attaching them.
    • Your subwoofer is now disconnected and ready to be replaced.
Jaiden Wiles
Membre depuis le 10/26/22
157 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 2-6, Petersen Fall 2022 Membre de l'équipe UMass Dartmouth, Team 2-6, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G6
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 48
Total : 768
