Introduction
This is a guide on how to disassemble an Amazon Echo Studio to be able to replace the subwoofer unit.
Ce dont vous avez besoin
Flip the device upside down.
Pry up the edge of the rubber base panel with a spudger, then pull the rest of it off by hand.
Remove the two screws located across from each other on the outside of the plastic ring shown.
Remove the plastic outer ring that hugs the inside of the edges of the device.
On the silver ring located on the outer edge of the plastic portion of the subwoofer, you will see four 2.7 mm screws. Use a Torx T10 screwdriver to remove them, in order to remove of the subwoofer.
Follow the wires from the subwoofer to the main board and disconnect the connector attaching them.
