Aller au contenu principal
Amazon Echo Tweeter Assembly Replacement
Ce dont vous avez besoin
  1. Amazon Echo Tweeter Assembly Replacement, Power and Speaker Driver Board: étape 1, image 1 de 1
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo Tweeter Assembly Replacement: étape 2, image 1 de 3 Amazon Echo Tweeter Assembly Replacement: étape 2, image 2 de 3 Amazon Echo Tweeter Assembly Replacement: étape 2, image 3 de 3
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo Tweeter Assembly Replacement: étape 3, image 1 de 1
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo Tweeter Assembly Replacement: étape 4, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
  5. Amazon Echo Tweeter Assembly Replacement: étape 5, image 1 de 2 Amazon Echo Tweeter Assembly Replacement: étape 5, image 2 de 2
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
  6. Amazon Echo Tweeter Assembly Replacement: étape 6, image 1 de 3 Amazon Echo Tweeter Assembly Replacement: étape 6, image 2 de 3 Amazon Echo Tweeter Assembly Replacement: étape 6, image 3 de 3
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
  7. Amazon Echo Tweeter Assembly Replacement, Tweeter Assembly: étape 7, image 1 de 2 Amazon Echo Tweeter Assembly Replacement, Tweeter Assembly: étape 7, image 2 de 2
    • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
  8. Amazon Echo Tweeter Assembly Replacement: étape 8, image 1 de 1
    • Peel off the black fabric wrapped around the Echo.
    • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
  9. Amazon Echo Tweeter Assembly Replacement: étape 9, image 1 de 3 Amazon Echo Tweeter Assembly Replacement: étape 9, image 2 de 3 Amazon Echo Tweeter Assembly Replacement: étape 9, image 3 de 3
    • Remove the four 42.8 mm T10 Torx screws around the tweeter.
    • Lift the tweeter and its attached housing from the device.
Alexander Albert
Membre depuis le 02/04/16
1 145 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 3-3, Wollert Spring 2016 Membre de l'équipe USF Tampa, Team 3-3, Wollert Spring 2016
USFT-WOLLERT-S16S3G3
4 membres
12 tutoriels rédigés
3 commentaires
I've gotten this far, but where do you get a replacement? No brand or model # on tweeter.
Kyle - Réponse
Are you saying removing it and replacing the same tweeter is what you have to do? It says no parts.
kathy1557 - Réponse
The primary purpose of this guide is to show you how to remove a failing tweeter so that you can replace it with a new one. The "no parts required" text appears at the top of this guide because the author didn't have a source for the replacement part.
Ron Davis -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 10
Total : 3,717
