Aller au contenu principal
Amazon Fire 5th Generation Speaker Replacement
Ce dont vous avez besoin
  1. Amazon Fire 5th Generation Speaker Replacement, Speaker: étape 1, image 1 de 2 Amazon Fire 5th Generation Speaker Replacement, Speaker: étape 1, image 2 de 2
    • Ensure that your device is turned off.
    • Remove any micro-SD card that may be installed in the Fire. Failure to do so could damage the micro-SD card itself or the micro-SD card reader on the Fire.
    • While holding the device firmly, wedge the iFixit Opening Tool into the crease along the outer edge of the device (as shown in the image).
    • Slowly, grind the iFixit Opening Tool into the crease along the outer edges of the device until the entire back cover loosens.
    • Then, remove the back cover from the device.
  2. Amazon Fire 5th Generation Speaker Replacement: étape 2, image 1 de 2 Amazon Fire 5th Generation Speaker Replacement: étape 2, image 2 de 2
    • Pry the speaker from the case using the iFixit Opening Tool.
    • Lift the speaker up from the device to remove the speaker wires from their groove in the case.
    • Be careful not to pull the speaker wires from the motherboard.
  3. Amazon Fire 5th Generation Speaker Replacement: étape 3, image 1 de 3 Amazon Fire 5th Generation Speaker Replacement: étape 3, image 2 de 3 Amazon Fire 5th Generation Speaker Replacement: étape 3, image 3 de 3
Amber Bunch
Membre depuis le 02/10/16
1 369 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 1-2, Nance Spring 2016 Membre de l'équipe USF Tampa, Team 1-2, Nance Spring 2016
USFT-NANCE-S16S1G2
3 membres
13 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 9
Total : 1,069
