Introduction
If your motherboard on your Amazon Fire Game Controller has been damaged or needs replacement, this guide will aid you through the process. Motherboard replacement may be necessary if controller inputs are incorrect or no longer working, or if a liquid had been in contact with your controller. A motherboard ties the components of an electronic device together in one spot, allowing for smooth communication and functionality. Before using this guide to help you replace the motherboard in your Amazon Fire Game Controller, make sure that it is absolutely in need of replacement. Some signs of this could be incomplete functions of buttons and triggers, lagging, or completely not working at all. If any of these issues apply to your Amazon Fire Game Controller, then continue reading this guide on replacing the motherboard. Happy fixing!
Ce dont vous avez besoin
Use a Triangle #2 screwdriver to remove the six 10 mm screws from the back of the controller.
