Aller au contenu principal
Amazon Fire HD 10 Rear Facing Camera Replacement
Ce dont vous avez besoin
  1. Amazon Fire HD 10 Rear Facing Camera Replacement, Screen: étape 1, image 1 de 3 Amazon Fire HD 10 Rear Facing Camera Replacement, Screen: étape 1, image 2 de 3 Amazon Fire HD 10 Rear Facing Camera Replacement, Screen: étape 1, image 3 de 3
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
  2. Amazon Fire HD 10 Rear Facing Camera Replacement: étape 2, image 1 de 1
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
  3. Amazon Fire HD 10 Rear Facing Camera Replacement: étape 3, image 1 de 2 Amazon Fire HD 10 Rear Facing Camera Replacement: étape 3, image 2 de 2
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
  4. Amazon Fire HD 10 Rear Facing Camera Replacement: étape 4, image 1 de 1
    • Remove the screen and digitizer from the case completely.
  5. Amazon Fire HD 10 Rear Facing Camera Replacement, Rear Facing Camera: étape 5, image 1 de 2 Amazon Fire HD 10 Rear Facing Camera Replacement, Rear Facing Camera: étape 5, image 2 de 2
    • Remove the single T5 Torx screw at the base of the camera.
    • Once removed, place the screw aside in a safe location.
  6. Amazon Fire HD 10 Rear Facing Camera Replacement: étape 6, image 1 de 2 Amazon Fire HD 10 Rear Facing Camera Replacement: étape 6, image 2 de 2
    • Lift the camera from the case using the plastic opening tool.
    • The camera is still connected to the motherboard via the ZIF connector.
  7. Amazon Fire HD 10 Rear Facing Camera Replacement: étape 7, image 1 de 2 Amazon Fire HD 10 Rear Facing Camera Replacement: étape 7, image 2 de 2
    • Gently grab the camera and pull to remove.
    • The camera is now free from the motherboard.
2 autres ont terminé cette réparation.
Jaie Hillery
Membre depuis le 10/07/14
1 718 Réputation
10 tutoriels rédigés
Équipe
USF Tampa, Team 16-6, Blackwell Winter 2016 Membre de l'équipe USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
3 membres
22 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 8
Total : 871
