Aller au contenu principal
Amazon Fire HD 3rd Gen Disassembly
Ce dont vous avez besoin
  1. Amazon Fire HD 3rd Gen Disassembly, Pry off the plastic back.: étape 1, image 1 de 3 Amazon Fire HD 3rd Gen Disassembly, Pry off the plastic back.: étape 1, image 2 de 3 Amazon Fire HD 3rd Gen Disassembly, Pry off the plastic back.: étape 1, image 3 de 3
    • Using a Jimmy, start at the volume control and work your way around by prying off the back and then lifting it back like a book.
  2. Amazon Fire HD 3rd Gen Disassembly, Peeling off the tape.: étape 2, image 1 de 3 Amazon Fire HD 3rd Gen Disassembly, Peeling off the tape.: étape 2, image 2 de 3 Amazon Fire HD 3rd Gen Disassembly, Peeling off the tape.: étape 2, image 3 de 3
    • Peel off the 2 yellow pieces of yellow tape on the battery.
  3. Amazon Fire HD 3rd Gen Disassembly, Disconnect the ribbon cables: étape 3, image 1 de 3 Amazon Fire HD 3rd Gen Disassembly, Disconnect the ribbon cables: étape 3, image 2 de 3 Amazon Fire HD 3rd Gen Disassembly, Disconnect the ribbon cables: étape 3, image 3 de 3
    • Take off all the ribbon cables connected to the main board. (Marked in Red)
    • On the 2 speakers marked in yellow, be sure to pull straight up. Then unclip the speaker cables.
  4. Amazon Fire HD 3rd Gen Disassembly, Unscrew speakers and gray bracket: étape 4, image 1 de 1
    • Using a T4 Torx driver, unscrew each of the 2 screws holding in the 2 speakers. (red)
    • Then, take out the 7 screws hold in the gray bracket (yellow)
    • Now, unscrew the 8 screws holding the motherboard. (green)
  5. Amazon Fire HD 3rd Gen Disassembly, Unscrew the I/O: étape 5, image 1 de 1
    • Next, use a T4 Torx Screwdriver again to unscrew the headphone jack and the Micro USB port.
  6. Amazon Fire HD 3rd Gen Disassembly, Take everything out.: étape 6, image 1 de 1
    • 1. Remove the Headphone and USB ports.
    • 2. Remove motherboard.
    • 3. Remove the speakers.
    • 4. Remove gray bracket with battery.
  7. Amazon Fire HD 3rd Gen Disassembly, Remove the screen.: étape 7, image 1 de 1
    • Now, using a T4, unscrew the 4 screws holding in the screen.
  8. Amazon Fire HD 3rd Gen Disassembly, Your Done!: étape 8, image 1 de 1
    • Congrats! Now follow the directions in reverse to reassemble your Fire!
Ligne d'arrivée
3 autres ont terminé cette réparation.
Cooper Anderson
Membre depuis le 09/08/17
541 Réputation
2 tutoriels rédigés
Équipe
Cooper Anderson Membre de l'équipe Cooper Anderson
Business
1 membre
2 tutoriels rédigés
Un commentaire
Please where can I get the digitizer?
Mine is shattered and I haven't used it for over 3years but I can still power it up.
Will very much appreciate a lead.
Patrick,
Nigeria
Patrick Mordi - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 9
Total : 1,608
