Introduction
The Amazon Fire 8 HD 12th Generation has a screen that is useable for near every function necessary on the tablet. To put it lightly, you cannot use the tablet at all without a functioning screen. Possible things that can lead to a broken screen range from cracking/breaking the screen itself, your tablet not being up to date, or the screen is not responding to your input/touch.
In this guide we will show you how to replace a faulty screen. This guide is difficult so please take your time and be patient when performing the steps. You may want to have a pair of safety gloves. These can be used throughout the guide as there are dangers such as loose or broken glass cutting you.
Ce dont vous avez besoin
Étape 1 Buttons
Attention : les étapes 1 à 2 sont issues d'un tutoriel marqué comme en cours.
Put picks around the corner and move them along the edge to pry the case off.
Once there is separation between the case and the screen, place a pick in between the screen and on the corner of the back case.
Using the iFixit opening tool, disconnect the battery from the circuit board.
Start off by heating the edges of the screen to melt the adhesive.
Insert the opening picks between the screen and device.
Outil utilisé dans cette étape :Tweezers$4.99
Heat up the little black square with yellow orange tape around it on the back of the device, atop the motherboard.
Once heated, remove the little black square using tweezers. Unhooking the screen from the screen.
Pulling the suction cup, fully remove the screen from the device.
