Aller au contenu principal
Amazon Fire HD 8 Screen Replacement
Ce dont vous avez besoin
  1. Amazon Fire HD 8 Screen Replacement, Screen: étape 1, image 1 de 2 Amazon Fire HD 8 Screen Replacement, Screen: étape 1, image 2 de 2
    • Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
    • Make sure you use sweeping motions with the heat gun, instead of hovering over one area.
  2. Amazon Fire HD 8 Screen Replacement: étape 2, image 1 de 1
    • After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
    • Be careful not to bend the screen by pushing it too far from the rest of the device.
  3. Amazon Fire HD 8 Screen Replacement: étape 3, image 1 de 3 Amazon Fire HD 8 Screen Replacement: étape 3, image 2 de 3 Amazon Fire HD 8 Screen Replacement: étape 3, image 3 de 3
    • Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device.
    • Be mindful of the orange cable connecting the screen to the mid-bottom of the device.
  4. Amazon Fire HD 8 Screen Replacement: étape 4, image 1 de 3 Amazon Fire HD 8 Screen Replacement: étape 4, image 2 de 3 Amazon Fire HD 8 Screen Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen.
27 autres ont terminé cette réparation.
Dan Shimkus
Membre depuis le 02/24/16
1 184 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 1-3, Leahy Spring 2016 Membre de l'équipe USF Tampa, Team 1-3, Leahy Spring 2016
USFT-LEAHY-S16S1G3
4 membres
17 tutoriels rédigés
18 commentaires
Very nice, but even Amazon is not marketing the replacement screens.
Wendy Huntington Parker Fages - Réponse
True, but if you happen to find another dysfunctional Fire ( with an intact screen) you can always harvest the display from that one and put it on your functioning unit. Long shot. But that's why this repair guide is still helpful even though parts aren't readily available.
Kelsea Weber -
Fingers crossed Amazon offers more parts in the future! :)
Kelsea Weber -
I ordered one from Amazon yesterday. Supposed to be 2 day shipping. Certainly not the $12 cheepy from China, but hopefully it will actually be shipped and delivered to my house. Any item Ive ever ordered that ended up being shipped directly from China has never found its way to my house and ends up costing about a months delay in the fixing of whatever device i have taken on the responsibility of to try & repair for someone.
Worth the $29 i’m paying at Amazon
Kitty Morgan -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 22
7 derniers jours : 121
30 derniers jours : 459
Total : 68,458
