Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Amazon Fire Phone Headphone Jack Replacement
Ce dont vous avez besoin
    1. Amazon Fire Phone Headphone Jack Replacement, Front Panel Assembly: étape 1, image 1 de 1
      • If the display is damaged use clear packing tape to contain any glass shards.
      • Make sure the entire surface of the display is covered with tape.
      • Wear safety glasses to protect your eyes.
      Demander à FixBot
      Ajouter un commentaire
    2. Amazon Fire Phone Headphone Jack Replacement, Preparation for Opening: étape 2, image 1 de 3 Amazon Fire Phone Headphone Jack Replacement, Preparation for Opening: étape 2, image 2 de 3 Amazon Fire Phone Headphone Jack Replacement, Preparation for Opening: étape 2, image 3 de 3
      • Power off your phone.
      • Remove the sim card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
      • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
      Demander à FixBot
    3. Amazon Fire Phone Headphone Jack Replacement, Manual Opening: étape 3, image 1 de 3 Amazon Fire Phone Headphone Jack Replacement, Manual Opening: étape 3, image 2 de 3 Amazon Fire Phone Headphone Jack Replacement, Manual Opening: étape 3, image 3 de 3
      • Press the single suction cup just above the home button.
      • While lifting up on the suction cup place the plastic opening tool at the rim of the screen, separating the screen from the back casing.
      • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
      • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone, freeing the two halves.
      Demander à FixBot
    4. Amazon Fire Phone Headphone Jack Replacement: étape 4, image 1 de 3 Amazon Fire Phone Headphone Jack Replacement: étape 4, image 2 de 3 Amazon Fire Phone Headphone Jack Replacement: étape 4, image 3 de 3
      • Remove the 1mm screw concealed in the headphone jack.
      • Afterwards the headphone jack will easily pop off.
      Demander à FixBot
3 autres ont terminé cette réparation.
Savannah Moen
Membre depuis le 10/29/15
267 Réputation
1 tutoriel rédigé
1 commentaire de tutoriel
hello sir i need amazon fire back casing in Pakistan
Kashif Arif - Réponse Partager
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 10
30 derniers jours : 47
Total : 2,407
