Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Amazon Fire Phone Micro-USB Port Replacement
Ce dont vous avez besoin
    1. Amazon Fire Phone Micro-USB Port Replacement, Tape the screen: étape 1, image 1 de 1
      • If the display is damaged, use clear packing tape to contain any glass shards.
      • Make sure the entire surface of the display is covered with tape.
      • Wear safety glasses to protect your eyes.
      Demander à FixBot
      Ajouter un commentaire
    2. Amazon Fire Phone Micro-USB Port Replacement, Power off, remove SIM card, remove screws: étape 2, image 1 de 3 Amazon Fire Phone Micro-USB Port Replacement, Power off, remove SIM card, remove screws: étape 2, image 2 de 3 Amazon Fire Phone Micro-USB Port Replacement, Power off, remove SIM card, remove screws: étape 2, image 3 de 3
      • Power off your phone.
      • Remove the SIM card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
      • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
      Demander à FixBot
    3. Amazon Fire Phone Micro-USB Port Replacement: étape 3, image 1 de 3 Amazon Fire Phone Micro-USB Port Replacement: étape 3, image 2 de 3 Amazon Fire Phone Micro-USB Port Replacement: étape 3, image 3 de 3
      • Press the small suction cup just above the home button.
      • While lifting up on the suction cup insert an opening pick into the crevice between the screen and back casing to pry the screen off carefully.
      • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
      • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone freeing the two halves of the phone.
      Demander à FixBot
    4. Amazon Fire Phone Micro-USB Port Replacement, Remove Bracket: étape 4, image 1 de 1
      • Using the J000 screwdriver head, remove the three 3mm screws holding the bracket in place.
      • Remove the silver bracket that was held into place by the three screws just removed.
      Demander à FixBot
    5. Amazon Fire Phone Micro-USB Port Replacement, Disconnect Battery: étape 5, image 1 de 1
      • Disconnect the battery connection cable by using the plastic opening tool and applying light pressure upwards on the cable.
      Demander à FixBot
    1. Amazon Fire Phone Micro-USB Port Replacement, Micro-USB Port: étape 6, image 1 de 2 Amazon Fire Phone Micro-USB Port Replacement, Micro-USB Port: étape 6, image 2 de 2
      • Unscrew the 1mm screw on the top left side of the phone
      • Maneuver the bracket off slowly
      Demander à FixBot
    2. Amazon Fire Phone Micro-USB Port Replacement: étape 7, image 1 de 3 Amazon Fire Phone Micro-USB Port Replacement: étape 7, image 2 de 3 Amazon Fire Phone Micro-USB Port Replacement: étape 7, image 3 de 3
      • Disconnect the 9 cables along the top and right side of motherboard using the plastic opening tool
      Demander à FixBot
    3. Amazon Fire Phone Micro-USB Port Replacement: étape 8, image 1 de 1
      • Unscrew the 3mm screw located on the top left side of the phone with a flat head
      Demander à FixBot
    4. Amazon Fire Phone Micro-USB Port Replacement: étape 9, image 1 de 3 Amazon Fire Phone Micro-USB Port Replacement: étape 9, image 2 de 3 Amazon Fire Phone Micro-USB Port Replacement: étape 9, image 3 de 3
      • Unscrew the four 2mm screws along the right side of the motherboard with a philips head
      Demander à FixBot
    5. Amazon Fire Phone Micro-USB Port Replacement: étape 10, image 1 de 2 Amazon Fire Phone Micro-USB Port Replacement: étape 10, image 2 de 2
      • Carefully lift up the motherboard and using the spudger pry camera from the camera holder
      Demander à FixBot
    6. Amazon Fire Phone Micro-USB Port Replacement: étape 11, image 1 de 1
      • Lift off bottom plastic piece with flat antenna cables
      Demander à FixBot
3 autres ont terminé cette réparation.
Kent Kawahara
Membre depuis le 10/01/15
110 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 5-7, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 5-7, Maness Fall 2015
CPSU-MANESS-F15S5G7
5 membres
60 tutoriels rédigés
2 commentaires de tutoriel
Incomplete...
Indeedthis isaname - Réponse Partager
one missing pic in step 9. also any ideas where i can get a replacement part?
Yu Ryu - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 38
Total : 3,000
