Aller au contenu principal
Amazon Fire TV Cube Speaker Replacement
Ce dont vous avez besoin
  1. Amazon Fire TV Cube Speaker Replacement, Speaker: étape 1, image 1 de 3 Amazon Fire TV Cube Speaker Replacement, Speaker: étape 1, image 2 de 3 Amazon Fire TV Cube Speaker Replacement, Speaker: étape 1, image 3 de 3
    • Using a metal spudger, push down between the edge seals on the base and pry off the base.
    • Do not confuse the top thin layer of rubber with the thick palette that needs to be removed.
    • This may require substantial force.
  2. Amazon Fire TV Cube Speaker Replacement: étape 2, image 1 de 3 Amazon Fire TV Cube Speaker Replacement: étape 2, image 2 de 3 Amazon Fire TV Cube Speaker Replacement: étape 2, image 3 de 3
    • Use the T-10 bit from the iFixit tool kit to unscrew the four 1.4 inch corner screws on top of the first layer.
    • There are 4 washers to go with each of the screws.
  3. Amazon Fire TV Cube Speaker Replacement: étape 3, image 1 de 1
    • Lift and remove the full frame.
  4. Amazon Fire TV Cube Speaker Replacement: étape 4, image 1 de 2 Amazon Fire TV Cube Speaker Replacement: étape 4, image 2 de 2
    • Lift and remove the speaker.
    • Carefully match the outlets on the speaker with the outlets on the motherboard.
2 autres ont terminé cette réparation.
Justice Davis
Membre depuis le 09/27/18
228 Réputation
1 tutoriel rédigé
Un commentaire
Our volume pauses every 11 minutes! Troubleshooting our Sono’s System…still doing it. Could this be our Fire Cube?
Lee - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 18
Total : 3,234
