Aller au contenu principal
Introduction
If your device is not working due to a faulty power cord, you can follow this guide to easily replace the faulty cord with a new one.
  1. Place the plastic opening tool in the space between the rubber and the plastic case of the device. Apply pressure by pushing upward on the case. Separate the bottom square rubber piece from the case using the plastic opening tool until all clips are detached.
    • Place the plastic opening tool in the space between the rubber and the plastic case of the device.
    • Apply pressure by pushing upward on the case.
    • Separate the bottom square rubber piece from the case using the plastic opening tool until all clips are detached.
  2. Locate the ten J#00 Phillips screws and remove them. Locate the ten J#00 Phillips screws and remove them.
    • Locate the ten J#00 Phillips screws and remove them.
  3. Place your finger on the short edge of the motherboard and lift it to separate it from the plastic case. Place your finger on the short edge of the motherboard and lift it to separate it from the plastic case. Place your finger on the short edge of the motherboard and lift it to separate it from the plastic case.
    • Place your finger on the short edge of the motherboard and lift it to separate it from the plastic case.
  4. With the mother board back facing you locate the power cord port found on the far left end. With the mother board back facing you locate the power cord port found on the far left end. With the mother board back facing you locate the power cord port found on the far left end.
    • With the mother board back facing you locate the power cord port found on the far left end.
  5. Locate the four soldering joints  for the power cord port found on the top side of the mother board. Desolder the joints of the  power cord port to release it from the motherboard. Place the new power cord port into its original location and solder its joints.
    • Locate the four soldering joints for the power cord port found on the top side of the mother board.
    • Desolder the joints of the power cord port to release it from the motherboard.
    • Place the new power cord port into its original location and solder its joints.
    • Use the iFixit soldering and desoldering guide.
5 autres ont terminé cette réparation.
jeffrey555
Membre depuis le 01/09/2015
424 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 16-3, Wollert Fall 2015 Membre de l'équipe USF Tampa, Team 16-3, Wollert Fall 2015
USFT-WOLLERT-F15S16G3
4 membres
16 tutoriels rédigés
2 commentaires
Aonde compro essa fonte ? wagnerj957@gmail.com
wagnerjr1977 - Réponse
Ola moro no Brasil minha fonte queimou aonde compro outra?
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 2,033
