Aller au contenu principal
AmazonBasics B0050BPWBQ Shredding Gears Replacement
Ce dont vous avez besoin
  1. AmazonBasics B0050BPWBQ Shredding Gears Replacement, Front and Back Panel Disassembly: étape 1, image 1 de 2 AmazonBasics B0050BPWBQ Shredding Gears Replacement, Front and Back Panel Disassembly: étape 1, image 2 de 2
    • The unit head needs to be switched to the off position and unplugged before any disassembly.
    • When removing screws in the following steps, make sure the unit is resting on a flat surface because pieces will easily come apart.
    • Remove seven 11 mm Phillips #1 screws from the underside of the head unit.
  2. AmazonBasics B0050BPWBQ Shredding Gears Replacement: étape 2, image 1 de 2 AmazonBasics B0050BPWBQ Shredding Gears Replacement: étape 2, image 2 de 2
    • Upon removal of the next screws, the front panel and the shredding component attached to it will fall apart from the back panel so have the unit resting on a flat surface.
    • Remove two 50 mm Phillips #1 screws from the middle of the underside of the head unit.
  3. AmazonBasics B0050BPWBQ Shredding Gears Replacement: étape 3, image 1 de 1
    • Lay the back panel away from the front panel on a flat surface.
    • The back panel will be light because it is only the plastic, while the front panel will be heavy with the shredding component attached to it.
  4. AmazonBasics B0050BPWBQ Shredding Gears Replacement: étape 4, image 1 de 2 AmazonBasics B0050BPWBQ Shredding Gears Replacement: étape 4, image 2 de 2
    • Find the green control board that is located next to the shredding motor.
    • Remove two 11 mm Phillips #1 screws located on opposite sides of the control board.
    • You may need to move wires over to find the screws.
  5. AmazonBasics B0050BPWBQ Shredding Gears Replacement, Shredding Gears: étape 5, image 1 de 2 AmazonBasics B0050BPWBQ Shredding Gears Replacement, Shredding Gears: étape 5, image 2 de 2
    • Unit may be greasy so you may want to grab paper towels/rag when completing these next steps.
    • Locate the large white gears on the side of the shredding unit.
    • Remove two 15 mm Phillips #1 screws that hold the motor in place.
  6. AmazonBasics B0050BPWBQ Shredding Gears Replacement: étape 6, image 1 de 3 AmazonBasics B0050BPWBQ Shredding Gears Replacement: étape 6, image 2 de 3 AmazonBasics B0050BPWBQ Shredding Gears Replacement: étape 6, image 3 de 3
    • Locate the three washers on the metal triangle piece.
    • Remove the three washers using two metal spudgers. To do this, place one spudger on each of the open ends of the washer. Push down with both spudgers at the same time to pop the washer off the gear.
    • Pull the metal triangle away from the gears.
  7. AmazonBasics B0050BPWBQ Shredding Gears Replacement: étape 7, image 1 de 2 AmazonBasics B0050BPWBQ Shredding Gears Replacement: étape 7, image 2 de 2
    • Remove the middle gear from the shredding unit.
    • Remove the top gear that was located under the middle gear.
  8. AmazonBasics B0050BPWBQ Shredding Gears Replacement: étape 8, image 1 de 2 AmazonBasics B0050BPWBQ Shredding Gears Replacement: étape 8, image 2 de 2
    • Remove the washer on the last gear using two metal spudgers. Again, place one spudger on each of the open ends of the washer. Push down with both spudgers at the same time to pop the washer off the gear.
    • Pull the last gear away from the metal shredding unit.
7 autres ont terminé cette réparation.
Natalie Meert
Membre depuis le 02/11/16
678 Réputation
4 tutoriels rédigés
Équipe
IUPUI, Team 2-4, Baechle Spring 2016 Membre de l'équipe IUPUI, Team 2-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G4
4 membres
8 tutoriels rédigés
7 commentaires de tutoriel
Where did you buy the replacement gears?
DIY Security Guy - Réponse
I agree, where do you get the replacement gears? I’ve looked everywhere!
CSHardware - Réponse
Taking the shredder apart is easy, finding and procuring the replacement gears is next to impossible…. It would be worth 130 points if you provided information on that.
Paul Williams - Réponse
I am also looking for parts.
Carl Young - Réponse
I need the circuit to determine the valué of a resistance that burned
Ximena A. Oyarzún González - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 47
Total : 11,174
