Aller au contenu principal
AmazonBasics B00Q3KFX8U Motor Replacement
Ce dont vous avez besoin
  1. AmazonBasics B00Q3KFX8U Motor Replacement, Drive Gear: étape 1, image 1 de 1
    • Remove the shredder assembly from the paper scrap bin.
  2. AmazonBasics B00Q3KFX8U Motor Replacement: étape 2, image 1 de 1
    • Remove the two 10mm PH1 screws holding the small black panel in place.
  3. AmazonBasics B00Q3KFX8U Motor Replacement: étape 3, image 1 de 2 AmazonBasics B00Q3KFX8U Motor Replacement: étape 3, image 2 de 2
    • Remove the six 14mm PH1 screws holding the bottom cover in place.
    • Remove the cover by lifting straight upwards.
    • One of the screws will be hidden beneath a warranty sticker. Simply push the head of the screwdriver through the sticker to access the screw.
  4. AmazonBasics B00Q3KFX8U Motor Replacement: étape 4, image 1 de 1
    • Remove the blade/motor assembly from the top cover by lifting straight upwards. Do not disconnect any wiring just yet.
    • The blades are sharp. Coming into contact with them may result in injury.
  5. AmazonBasics B00Q3KFX8U Motor Replacement: étape 5, image 1 de 2 AmazonBasics B00Q3KFX8U Motor Replacement: étape 5, image 2 de 2
    • Remove the five 8mm PH2 screws from the bracket holding the gears in place.
  6. AmazonBasics B00Q3KFX8U Motor Replacement: étape 6, image 1 de 1
    • Use a metal spudger to pry the bracket from the main shredder assembly.
    • If the bracket is attached too tightly for the spudger, carefully use a metal screwdriver to pry it loose.
  7. AmazonBasics B00Q3KFX8U Motor Replacement: étape 7, image 1 de 2 AmazonBasics B00Q3KFX8U Motor Replacement: étape 7, image 2 de 2
    • Remove the two plastic drive gears from the shredder assembly by lifting straight upwards.
  8. AmazonBasics B00Q3KFX8U Motor Replacement, Motor: étape 8, image 1 de 1
    • Remove the four 18mm PH2 screws holding the motor to the main shredder assembly.
  9. AmazonBasics B00Q3KFX8U Motor Replacement: étape 9, image 1 de 1
    • Disconnect the motor from the motherboard by either clipping the wires, or using a soldering iron to disconnect the wires directly at the board.
    • To reattach the motor, solder the wires back together, or to the motherboard depending on how you removed them.
William Foley
Membre depuis le 03/25/16
548 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-3, Miles Spring 2016 Membre de l'équipe UMass Dartmouth, Team 1-3, Miles Spring 2016
UMASSD-MILES-S16S1G3
2 membres
4 tutoriels rédigés
1 commentaire de tutoriel
Do you sell motor?
Binh - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 909
