Introduction
Sometimes the Micro USB Jack will stop working properly and may need replacing. This guide requires use of a Soldering Iron and should only be attempted by those with soldering experience. If soldered incorrectly, your device may be permanently damaged.
Ce dont vous avez besoin
Hold the speaker firmly and wedge a plastic opening tool in between the faceplate and the body of the speaker.
Move the tool back and forth along the entire perimeter of the face plate until you feel the plate loosen, then pry the plate off.
2 autres ont terminé cette réparation.
Un commentaire
that's awesome didn't i would find a tutorial but here it is. thanks man. What kind of usb connector do i use.
