Aller au contenu principal
Ambient Weather WS-1001-Wifi LCD Screen Replacement
Ce dont vous avez besoin
  1. Ambient Weather WS-1001-Wifi LCD Screen Replacement, LCD Screen: étape 1, image 1 de 1
    • First, you will need to remove all four M2x1-7 screws (7mm length) located on the back of the device. This should be done using a Phillips #1 screw driver.
  2. Ambient Weather WS-1001-Wifi LCD Screen Replacement: étape 2, image 1 de 1
    • From the side of the device use the plastic opening tool to pry the gray front casing from the rear black casing.
    • The ribbon cable is attached inside so the two pieces will not come completely apart. See step 3.
  3. Ambient Weather WS-1001-Wifi LCD Screen Replacement: étape 3, image 1 de 1
    • Using a plastic opening tool, carefully press the black bar towards the ribbon and away from the white bar in order to release it.
    • The ribbon cable should come out and be attached to the back of the LCD screen resulting in two separate pieces.
  4. Ambient Weather WS-1001-Wifi LCD Screen Replacement: étape 4, image 1 de 2 Ambient Weather WS-1001-Wifi LCD Screen Replacement: étape 4, image 2 de 2
    • Next, you need to remove the LCD screen from the front casing.
    • Push on the front of the LCD screen to pop it out as seen in picture 2.
Jeremiah Miskimen
Membre depuis le 11/06/17
107 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S1-G2, Harley Fall 2017 Membre de l'équipe IUPUI, Team S1-G2, Harley Fall 2017
IUPUI-HARLEY-F17S1G2
4 membres
3 tutoriels rédigés
2 commentaires
Pretty useless guide since this is all pretty self explanatory with no reference on where to get a replacement or even a part number
Jared Dykstra - Réponse
Exactly right.
j drag -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 369
