Aller au contenu principal
American Sanders EZSand Orbital Sander 07163A 2017 Driver Pad Replacement
Ce dont vous avez besoin
  1. American Sanders EZSand Orbital Sander 07163A 2017 Driver Pad Replacement, Remove the sandpaper disc: étape 1, image 1 de 1
    • Before you begin, be sure that the sander is unplugged and powered off.
    • Carefully tilt the sander back and lay it down on its side, exposing the three sanding pads on the bottom.
  2. American Sanders EZSand Orbital Sander 07163A 2017 Driver Pad Replacement: étape 2, image 1 de 1
    • Peel the hook-and-loop sandpaper disc off of the driver assembly.
  3. American Sanders EZSand Orbital Sander 07163A 2017 Driver Pad Replacement, Remove the driver pad: étape 3, image 1 de 2 American Sanders EZSand Orbital Sander 07163A 2017 Driver Pad Replacement, Remove the driver pad: étape 3, image 2 de 2
    • Use a 3 mm hex key or driver bit to remove the six 11.9 mm-long screws securing the driver pad.
    • Remove the driver pad from the sanding disc.
2 autres ont terminé cette réparation.
Adam O'Camb
Membre depuis le 04/11/15
177 792 Réputation
418 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 13
30 derniers jours : 78
Total : 2,463
