Introduction
This manual shows how to simply replace the sensor on the Anker 2.4G wireless mouse. Before moving on with the first step, check the battery casing for any corrosion or visible damage. Beware, this guide requires use of a soldering iron which needs to be handled with caution. The instructions on how to solder can be found here Comment souder et dessouder des connexions.
Ce dont vous avez besoin
Using a spudger, carefully pry off the stickers to reveal the location of four screws.
2 autres ont terminé cette réparation.
