Introduction
This is a replacement guide for the front panel of your Anker Soundcore 3. If there seems to be any sort of sound distortion, then it could be due to a collection of dust or debris stuck behind the front panel. This guide may prove to be a quick and easy solution to this problem. This is the shortest and easiest of all of the guides so you shouldn't run into much trouble at all. Please ensure that you don't pry too hard on the front panel as you don't want to accidentally break it.
Ce dont vous avez besoin
Gently heat the perimeter of the device with a hairdryer to loosen the adhesive.
Insert a metal spudger in between the speaker's front grill and chassis.
Continuously pry around the edges of the casing; you should hear the glue start to separate from the front panel before the two parts separate.
