Aller au contenu principal
Anker Soundcore Life Q30 Earphone Cushion Replacement
Ce dont vous avez besoin
  1. Anker Soundcore Life Q30 Earphone Cushion Replacement, Earphone Cushion: étape 1, image 1 de 2 Anker Soundcore Life Q30 Earphone Cushion Replacement, Earphone Cushion: étape 1, image 2 de 2
    • Orient the headphones such that the headphone speakers are closest to you, and the headband is furthest from you.
    • Adjust the folding hinge to where the speakers are facing up.
    • Make sure you can easily reach the edge where the cushion connects to the rest of the headphones.
  2. Anker Soundcore Life Q30 Earphone Cushion Replacement: étape 2, image 1 de 3 Anker Soundcore Life Q30 Earphone Cushion Replacement: étape 2, image 2 de 3 Anker Soundcore Life Q30 Earphone Cushion Replacement: étape 2, image 3 de 3
    • Using one hand, hold the right side of the headphones still.
    • Using your other hand, slide the plastic opening tool in the edge along the cushion.
    • Gently pry the cushion off using the plastic opening tool.
    • Set the right ear cushion aside and repeat this step for the left side of the headphones.
  3. Anker Soundcore Life Q30 Earphone Cushion Replacement: étape 3, image 1 de 2 Anker Soundcore Life Q30 Earphone Cushion Replacement: étape 3, image 2 de 2
    • Remove the white foam pieces from the old cushions, noting their orientation.
    • Insert the white foam pieces from the old cushions into the replacement cushions. Make sure to set them in the same orientation they were in previously.
Nathan
Membre depuis le 02/15/24
431 Réputation
3 tutoriels rédigés
Équipe
University of Memphis, Team 4-1, Sneed Spring 2024 Membre de l'équipe University of Memphis, Team 4-1, Sneed Spring 2024
UM-SNEED-S24S4G1
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 65
30 derniers jours : 180
Total : 358
