Introduction
Is your Anker Soundcore Space Q45 power button stuck or not working, preventing you from using the device to its full capability? If so, here is a guide to fix the problem in a few easy steps.
Ce dont vous avez besoin
Use the iFixit opening tool to disconnect six clips holding the outer covering in place.
Remove two screws from the motherboard with a Phillips screwdriver.
Remove the motherboard from the headphones.
Use a soldering iron to desolder the contacts connected to the three buttons on the bottom left-hand side of the motherboard.
