Aller au contenu principal
Anki Vector Infrared Sensor Replacement
Ce dont vous avez besoin
  1. Anki Vector Infrared Sensor Replacement, Belts: étape 1, image 1 de 1
    • Raise Vector's arms above his head.
  2. Anki Vector Infrared Sensor Replacement: étape 2, image 1 de 2 Anki Vector Infrared Sensor Replacement: étape 2, image 2 de 2
    • Using your thumb and index finger, grab the lower portion of the belt near the large wheel and pull the belt off.
    • Repeat on the other side.
  3. Anki Vector Infrared Sensor Replacement, Infrared Sensor: étape 3, image 1 de 2 Anki Vector Infrared Sensor Replacement, Infrared Sensor: étape 3, image 2 de 2
    • Pull each front wheel cover off.
    • This will require a good amount of force due to the three clips holding it in place.
  4. Anki Vector Infrared Sensor Replacement: étape 4, image 1 de 2 Anki Vector Infrared Sensor Replacement: étape 4, image 2 de 2
    • Unscrew the wheel with the Phillips #00 screwdriver and gently remove it.
  5. Anki Vector Infrared Sensor Replacement: étape 5, image 1 de 1
    • Unscrew the two body screws beneath the wheel using the same screwdriver.
  6. Anki Vector Infrared Sensor Replacement: étape 6, image 1 de 2 Anki Vector Infrared Sensor Replacement: étape 6, image 2 de 2
    • Gently pull off the front panel to unplug the Infrared sensor.
    • Be careful when pulling off the front panel. The Sensor is connected by wires to both the panel and the device.
Shay Takei
Membre depuis le 04/16/19
1 570 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S2-G6, Maness Spring 2019 Membre de l'équipe Cal Poly, Team S2-G6, Maness Spring 2019
CPSU-MANESS-S19S2G6
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 703
